yes... another effn boost question
Mephisto
These trucks are cursed
ok this one should be pretty easy...
on 101oct and my ultimate set to T3-22, im still only getting about 17-18lbs of boost. should i adjust the wastegate to acheive the extra couple lbs? or is that gonna say night night to my motor and leave me stranded riding home with Tex the flatbed tow truck driver?
GM TURBO
Sell Out
Are you running Datamaster when you are running the T3-22 program? Knock related?
It could be because the stocker turbo design doesn't do much above 18# of boost - or so I am told.
Mephisto
the last DM run i did, i peaked out at 1.8* of knock, so i dont think its knock related, i also just went through and checked all my vacuum lines, which are good. the only problem im seeing is that i get 10lbs quick then it takes awhile to build up from there...
Tooky
Serious about performance
Neal can you send me one of those DM runs where the boost hits 10 quick and then takes a while to build from there? I bet you're using the Ultimate chip, too...
Was your spool this bad with the stock chip?
