from the cd
6E3-C4-4 4.3L TURBO (VIN Z) DRIVEABILITY AND EMISSIONS
V3211
CHART C-4C
IGNITION SYSTEM CHECK
(REMOTE COIL)
4.3L TURBO (VIN Z) SYCLONE AND TYPHOON (PORT)
ule from the “BATT” to the “TACH” terminal. Test Description: Numbers below refer to circled
numbers on the diagnostic chart.
1. Two wires are checked to ensure that an open is
not present in a spark plug wire.
1A. If spark occurs with 4 terminal distributor
connector disconnected, pick-up coil output is too
low for EST operation.
2. A spark indicates the problem must be the
distributor cap or rotor.
3. Normally, there should be battery voltage at the
“C” and “+” terminals. Low voltage would
indicate an open or a high resistance circuit from
the distributor to the coil or ignition switch. If “C”
terminal voltage was low, but “+” terminal
voltage is 10 volts or more, circuit from “C”
terminal to ignition coil or ignition coil primary
winding is open.
5. Applying voltage (1.5 to 8 volts) to module
terminal “P” should turn the module “ON” and the
tachometer terminal voltage should drop to about
7-9 volts. This test will determine whether the
module or coil is faulty or if the pick-up coil is not
generating the proper signal to turn the module
“ON.” This test can be performed by using a DC
battery with a rating of 1.5 to 8 volts. The use of
the test light is mainly to allow the “P” terminal to
be probed more easily.
4. Check for a shorted module or grounded circuit
from the ignition coil to the module. The distributor
module should be turned “OFF.” Normal voltage
should be about 12 volts.
Some digital multi-meters can also be used to
trigger the module by selecting ohms, usually the
diode position. In this position the meter may
have a voltage across its terminals which can be
used to trigger the module. The voltage in the
ohms position can be checked by using a second
meter or by checking the manufacturer’s
specification of the tool being used.
If the module is turned “ON,” the voltage
would be low, but above 1 volt. This could cause
the ignition coil to fail from excessive heat.
With an open ignition coil primary winding, a
small amount of voltage will leak through the mod-
6. This should turn “OFF” the module and cause a
spark. If no spark occurs, the fault is most likely
in the ignition coil because most module problems
would have been found before this point in the
procedure. A module tester (J 24642-F) could determine
which is at fault.
hope this helps
ed
