Aeromotive 340 stealth pump
jmcguigan77
Anyone here running the this pump?... also witch version did you use and how do you like it?
Sent from my SM-N910P using Tapatalk
jmcguigan77
Re: Aeromotive 340 stealth pump
Awesome now I just need to find out which one works with the ty
Sent from my iPhone using Tapatalk
Slyclone
Well-known member
I ran one in syclone, it requires a fuel pump hotwire for higher amp draw. Racetronix hotwire.
I have the info in a folder on the one I used for syclone.
jmcguigan77
Great info do you remember what version you used was it the center or offset line inputs
Brianawd
Have not run on in my typhoon but installed one in my evo 8 last year. It failed 3 months after install. Got a new on and it failed 5 months after install. Switched to a walbro 450. no issues. Also at the same time my friend installed one in his evo.
his failed after 6 months. all 3 were the brand new e85 compatible 340 pumps. Lots of people having issues with them. Evo/GTR/STI. But could just be a issue with the design of them for the import world.
Von Rottes
I used one On my LS-S10, should be the offset...I think summit has it labeled as a GM type pump.
As stated above, at the VERY least install the racetronix upgraded bulkhead..
Found out the hard way the stock bulkhead isn't good for a high current ... melted the power/ground wires and melted the bulkhead.
I've had the 340 in my S10 since 2013 when I first put the LS in it.
