randy merritt
Re: Debating on selling my Typhoon
One other thing you might want to condider: When my truck was more stock, I had good luck running a Code58 tune that I downloaded off of Josh Straub's web site, powertuneplus.com. If you have basically a stock build, which it appears you do, you can install one of his tunes in your truck using the Moates stuff you have now. Just keep an eye on knock, and I assume you have a WB o2 sensor to keep and eye on that also.Well I have all my stuff from Moates to switch it to code59 and then I'll probably look into T-Bone's suggestion of contacting Jeff Scott.
To answer some of the questions posed I have verified the timing multiple times and checked grounds, connectors, wiring and ignition.
Someone posed the idea of the Ultimate chip not being configured for my truck and that sounds like a reasonable idea. I have no way to verify what the chip in it is set up for but its coming out. Maybe that will start me on the road to success.
Thanks for all the support though I think I had all but talked myself into a for sale sign and that would have sucked when the next guy spent a day getting it worked out and enjoyed all of my time and effort. So the joys continue. I'll keep you guys posted on what comes of it all. Worst thing that can happen is it sits for a bit.
