TYTILIDIE said:I tossed mine and have never had a tech say a word about it.
blk00z28 said:...If you want to really get tricky. You can take the EGR off, cut the pin that extends into the manifold, put a block off plate between the EGR and the manifold and call it a day. That way its blocked off for good. But you still pass the "look."
DynaGlide said:And if you want to get extremely tricky, you can pull your top end apart, weld the EGR slot in the intake manifold, mill it flat, and reinstall. That way you can leave your pretty EGR valve in place, and not even have to worry about the exhaust gas heating up your manifold and plenum! As an alternative, you can use JB Weld in the EGR slot if you don't have a welder.
BTW, this is right way to do it, but arguably overkill.![]()
