electric fan
dpw41285
Spoolin'
will one 16in fan be sufficent for cooling ? summer normally gets around 85 deg in indiana but it will only be driven maybe 9mi to work on the interstate or to the lake avg speed of 60mph. othere then that night driving maybe 20mi round trip to pick up my son...i am normally found in the vette in the summer months. i think the fan is 1500cfm puller i bought from advanced auto.
dpw41285
Spoolin'
Re: electric fan
Thanks but the mechanical fan is not for me. It's big ugly takes up too much room parasitc loss and out of date. My truck runs excellent with out it. Night and day diffrence, it's way quieter smoother idle a weird vibration has gone away and overall the motor responds better. Am I saying I gAined .5 sec @ the track, no . But I definatley gained tons of drivability. I am more curious if my fan is powerfully enough, I donth think I'll be persuaded to go back to mechanical
Injected1
Re: electric fan
I use 2x 12" ffdynamics fans works great temps never get over 190, even on 105 degree days. Lifetime warrranty and they look great
BoostedSUV
Re: electric fan
I'm running a single fan for an S-10 radiator. Works fine... Even sitting in traffic on 90+ degree days it won't get above 190 degrees. I with you, elec fans are much quieter and cleaner looking. A dual fan setup would be ideal but a single works fine.
dpw41285
Spoolin'
Re: electric fan
Awesome that's what I needed to know I have the fan control wired in it's adjustable from 70deg-210deg and it's wired into to my ac compreossor to auto kick on
qbnkiller
Conflaguration Specialist
Re: electric fan
Go to the junk yard and look for the Ford 3.8L V6 fan setup. It is a monster fan capable of more than 5000cfm on high speed. I have mine, and never had to switch it off of LOW speed (with a short-filled block).
i8av8
Re: electric fan
i've been wanting to do the elec. fan set-up also and was curious to know which size/s would be sufficient for our motors. after staring at my set-up, i think the loud, bulky yet, sufficient stock fan is my best bet. i have the front mount ic and oil and trani. cooler plus radiator to pull air through.
i don't think electric fans would do it for me. although, i hear the mark8 fans are pretty strong. i just don't want to do all the swapping and come to find out the fan/s are not strong enough and have to put everything back.
dpw41285
Spoolin'
Re: electric fan
i dont think the fan i got is gonna cut it, it looks to be about half the cfm of what everyone is using. then again everyone may have an overkill set up. a 16in fan move quite abit of air
SloGN
9Sec Alky V6
Re: electric fan
If the fan clutch is working properly it don't drag as much power as one would think from the engine.
Just think if that fan draws 30 amps the alt is now having to work harder to supply that 30 amps. Well that power has to come from somewhere. you got it the engine.
Here is another interesting thing. As you change from one energy sousrce to another there are losses there too. so you may actually may be losing more power with the elec fan set-up.
One more thing the stock electrical system is doing good to supply it/s own equipment much less than say another 30 amp device.
Well the solution to that is a cs144 alt that is larger and consumes more power to turn it. So there is another reduction in power.
just some of my thoughts on the subject.
Flame suit on.
dpw41285
Spoolin'
Re: electric fan
the ole supercharger theory, i still think i am ahead. dont care so much about the 7hp difference as the driveability. im teliing ya huge difference night and day. i see what your saying though, the fan only has a 16.6 amp draw at start up then significantly drops while running. head lights dont even dim
