Have you checked ohm resistance on the injectors?
Have you done a compression check on it recently?
When all the dust settles, my guess is it WILL be injector related just because his issue almost exactly duplicates the one I had. Time will tell.....
I agree but I really expected to see fuel in a cylinder when I pulled the plugs the next morning.
Pulled all the plugs. They're all pig rich black but #1 had a slight amount of visible gas on it.
I cranked the truck with the plugs out (after letting the fuel pressure drop to 0 over night) no raw fuel came out of any of the cylinders.
Hmmmmmmmmmmm.
I can't quite put my finger on it. I guess I'll take a look in the SyTy supplement and see what it says.
#1. I would send a log of the truck running to Nolan or another experienced tuner to look at things..
#2 If the tune looks ok, I would still consider sending the injectors out to at least have them tested to make sure they aren't the culprit...not worth loosing an engine over..I send my injectors out at least once a season just for piece of mind (I had one clog before).
by the way the correct way to test a fuel pressure regulator is to first unhook the engine vacume and hook up a hand operated vacume pump with gauge- pump it up to 20" of vacuum and make sure the pressure doesn't bleed off- if it is its a ruptured diaphragm. Then start the engine and release the vacuum and pump it back up while checking the fuel pressure to verify its operation
fuel smell is a telltale but if your running rich it may be hard to distinguish excessive fuel smell from inside of the intake to the line, most failed fuel regulators ive seen usualy drip fuel from the vacuum line when you unplug it- or are noticeably wet.
im with everyone else though- it seems to me like an injector issue. if you can seal off the pressure and return lines with pressure in them- pinch off rubber lines or install shutoffs- you can verify an injector leak
What is the AFR at idle? If you need to lean it out in Code59, just go into the F28 table at idle when the truck is warm and that will set it for you.
What temp does the truck think it is at? A bad coolant sensor happened to me and made it rich as hell. In DM, what temp do you see? Ignore the console gauge obviously.
What does your o2 sensor signal look like at idle?
Did you try installing the stock distributor and I missed the post?
