BoostedSUV
Re: Gas in the oil
Ok, just came in from from the garage. I compression tested the motor with a cheap harbor freight compression tester. 1,3,4,5 are all 118-120, 2 and 6 are are about 115.
I put a hand vacuum pump on all the vacuum lines. Everything holds 20hg except the fuel reg. the fuel reg will pump up to 20 and slow bleed off. Not immediately but fairly quickly.
While cranking the motor with a hand held starter switch I could shine a light into the cylinders better while cranking. #4 was puffing moisture but it didn't smell like fuel. Im really hoping it's not antifreeze. Motor is fresh and has cometic gaskets. Right now I feel so defeated with this truck. Oil is not milky it's definitely light brown and smells like fuel. I don't even know what to do now
