Gaskets??
summerwolf
02 blazer 5 spd
What does everyone do for their turbo gaskets...I have the one to mate it to the manifolds but what about the turbo-downpipe gasket, felpro isn't showing one and GM said it was discontinued :rotf:
summerwolf
02 blazer 5 spd
Re: Gaskets??
:roll: well, thats useful to know...lol. No wonder that gasket is discontinues :rotf: I guess I'm going to have to find a fun way to do the custom downpipe...
Loeryder
Re: Gaskets??
GM offered a manifold/head crush type gasket to help seal some v-8 heads.
Since the ports are almost the same we can use those.
Turbotime.us offers them.
The Turbo to DP is a std 3 bolt exhaust configuration. 2.5" I believe.
The oil drain gasket on the bottom of the turbo can be found at hahnracecraft.com
hahn rocks.
VermontTy
Support Our Troops
Re: Gaskets??
From the manifold to the turbo flange, I put a thin layer of bearing grease on both surfaces and bolted them together. Read somewhere that it 'cooks' and provides a nice seal when used in moderation.
summerwolf
02 blazer 5 spd
Re: Gaskets??
alright thanks for those tips, guess it won't be so bad after all! Just kinda surprising they didn't use anything from the factory, thats just weird
Captain Morgan
Moderated User
Re: Gaskets??
I do actually use Anti-Seize on all my gaskets. It fills in the little imperfections and makes the best seal possible, and it also allows the gasket to come back out in 1 piece, so you can reuse it if you happen to need to take everything apart 2 days later, or save on cleanup time if it needs to come apart 5 years from now :tup:
summerwolf
02 blazer 5 spd
Re: Gaskets??
I just bought a pair of copper gaskets like mentioned above for GM v8's, perfect fit...I got the turbo cleaned up and the wastegate ported and they included a gasket to mate it to the manifolds....so I guess all thats left now is get an intercooler, FMU, SS oil lines, and get all on there and tuned with a custom downpipe.... :rotf: if only it were as simple as it sounds on screen
Re: Gaskets??
Do these copper gaskets work then?
What about the turbo downpipe - is there an effective solution there?
