How to install stock arm coil overs
Mr Bravada
Re: How to install stock arm coil overs
E-RUE said:
guys we really need a couple more people involved to pull this off...... right now i only have 5 orders.
e
once i figure out what spring i need i am in. also, since i would be paying with credit card i would pay the C/C fees (you said 2-3% right?) or if pressed i can pay with check
E-Rue
GP is over, i shipped the first kit yesterday and the rest are going out as soon as i get the rest of the shocks in.
if you missed the GP its not a huge deal, regular price is only $40 more than the GP price.
e
ChevelleDude71
Lo Boost
I tore my torsion bars out saturday night and ordered these online that same night, I'll post pictures once I have them installed. :tup:
E-Rue
i accidentally sent someone a mismatched set of springs. when you guys get your kits can you please check to make sure your part numbers match on both springs? one of you has a random 575lb spring thats meant for my truck.
e
Rinkrat456
Got LS1?
What would the spring rate recommendation be for a 3050lb regular cab 4x4 Sonoma?
550lb?
George Blake
DONATING MEMBER
E, I've got the bushings and ball joints but that's it. Please let me know when you can send the rest of the stuff. I need to get my truck out of the shop so I can start working on stuff for other guys....can't let it down without the springs and shocks
oboym
e
Just my luck. I got your 575 spring
E-Rue
george your order went out thismorning.
the spring screw up ill take care of tonight...... sorry about that.
550lb?
we have many different spring rates, i can make a suggestion for your application once you place an order.
e
Rinkrat456
Got LS1?
I'm at school and will be back Christmas break after the semester ends. I'm doing all my homework and parts research now so that when I return, I can order everything at once so things are available for the build come spring break. Is there an easy one-size-fits-3050lb-all answer or do you want me to call first because there are other variables? If so, what?
MIGHTYMOUSE
Turbo F body guy
sounds good, i'd like to see some other customer installation pics and feedback
oboym
Well i got the passenger side in and i did not have to put it in upside down little more or less work. but i think it will be better then going upside down. i can adjust the spring with out taking it apart and i have more room at the cv shaft.
my ? is why did you guys put them in upside down.
oboym
Got the drivers side in same way not upside down. after looking close. (with this setup) the front of the truck will have to sit about 26 1/2" or so "( from ground to cladding) to have any kind of shock travel.
( my tire size 255/R50/16 )
(This setup At 29" its toped out) (Stock setup is around 33"- 34")
So at 26 1/2"or so will give me only about 2" each way. A longer shock would be better or more shock travel.
MIGHTYMOUSE
Turbo F body guy
it makes too much sense to me to install the shock in the normal position as in oboym's last picture
what was the original reason for having them upside down?
BigBadSmoosh
honestly no idea.. but it works great.. and its easy as hell to adjust the shock..
The clearances sometime get really tight at the top. Some trucks will fit not fit that way (or only one side will)
oboym
Can you adjust the spring when its upside down ?
