truckins10
Okay guys I emailed Ty2185 the upgraded pics with some measurements. If you guys need further measurements let me know with specifics. Fern
truckins10 said:Okay guys I emailed Ty2185 the upgraded pics with some measurements. If you guys need further measurements let me know with specifics. Fern
truckins10 said:I did my best on the measurements, should be good. I didt want to give the hole centers because there would be to much guessing on my part so I just gave the outside dimentions. Couldnt you guys just resize these brackets in a program, print them out, then measure the external diamentions I gave and compare them to the print?? This would seem easier determining the hole locations?? The part of the bracket with the curve cut is the part that bolts to the spindle. If you cut the bracket the exact external diamentions, remove the hub, then you can mark the holes from the opposit side of the spindle. Fern
one word: badass!JS Manufacturing said:from my past costs, $40 a set + shipping lazer cut.
Crazy J said:wow, this post hasn't gone anywhere.
well i talked to someone at Baer and found out that their brackets will work if used with c5 corvette calipers and their centering rings. after reading about 50 websites about various brake swaps it looks like the f-body calipers are similar enough to also be used.
since then i've decided to go with 13" c5 brakes in front, i'll probably use Baers brackets, if i do i can send one over to JS Designs to get measured and duplicated if anyone's interested.
