wantingasy
Re: Oil filter adaptor FYI.
My stock oil lines from the filter housing to the block have been leaking so I'm thinking about just replacing them all with these ss braided lines. I have a ? though. In the picture where the fittings are going into the housing, the stock housing has that adapter plate or whatever it's called. To get these anodized fittings to work, does that adapter plate just come off and those fitting can screw right in? Also, is that the same thing that would have to happen for the one on the block too?jwaller said:![]()
does this help? I did it all in -8 and used 45deg angle ports on the adaptor on the block.
