Re: Power steering pump removal
I know how to read. The question is did I remember what I read?:rotf: I was generally just ranting. There are a couple of things that tend to not make sense in this forum and fighting that bolt behind the pump through the bracket and into the head is one of them. So no worries.
Regarding the bolt in the picture no need to remove it. That bracket that goes up to the alt and out to the ex manifold comes out with the pump. IOW remove top rad shroud and fan/clutch to gain access to the pully. Use tool to remove said pully. Remove PS pump bolts holding the pump to the bracket. (3 in my case, 4 in yours I guess.) Drop/wiggle the pump enough to gain access to the bastard location bolt in the bracket. Remove remainder of bolts. Counting from memory there is 5. The one we're talking about, one buried in the bracket you can't see, another one near the intake and two way down at the bottom. Bracket is now loose and pump is free also along with the steel bracket in your pic.
On reinstall I find it easier to sorta get them into place all at the same time. The pump just fits between the bracket and the block and is PITA to install with the bracket bolted up solid. To me it's worthwhile to get everything in position with the pump slightly below (IOW the reverse of removal) so the bolt is exposed. Tighten all the bracket bolts, bring the pump into position, reattach it to the bracket, pull/press (whatever) the pulley on and you're done.
You can't do that because of your bad threads. I have a pump I could sell you. If you want it LMK, I'll take some pics and figure a price (won't be much) figure the shipping and you can have it.
Hope I was clear AND you get things sorted out.
