Re: Pulled engine today and found... (pics)
One of my back issues of Hot Rod actually has a letter from Ed Hess published in it talking about the oil pump failure. According to Melling, the newer pumps were made with thinner casting walls to save a buck so their parts stay cheaper. Apparently they are *not* supposed to be used in cars with solid motor mounts or high vibration vehicles (IIRC they said there is a warning label on the box).
Post scrounged from the Net:
" Melling’s design of GM’s Small Block Chevy oil pump was updated in 2004, see attached bulletin. At that time changes were made to the standard volume, M-55 & M155, and the high volume, M-55HV & M155HV, pumps. The changes improved many aspects of the pumps as compared to the original GM pump. To respond to customers requests one of the areas that improved was the hot idle performance of the pump. Durability was improved by eliminating a possible failure mode as noted in the bulletin. Casting improvements allowed the wall thickness of the housing around the gears to be reduced to reduce weight. Additional support rips were added to the neck area on the high volume pump casting. For stock replacement applications the changes will only increase customer satisfaction with our products.
For performance applications Melling recommends an M-Select oil pump be used, especially in solid motor mount applications. Melling has available a full line of SB Chevy performance oil pumps. Not only does the M-Select line of SB Chevy performance pumps utilize the previous casting design but are available with design features to further increase performance and durability. In addition the M-Select pumps are CNC machined to exacting tolerances and surface finishes. The M-Select line was created to provide engine builders a cheap insurance policy to improve one of the most overlooked critical components in a performance engine build, the oil pump. "
