Aeroking
e.i.
I have searched, and read all the 101 posts.
I took my upper/lower intake off to clean, and paint them. I put everything back together, and started it up.
I set the distributor back to where i had it before my tear down.
But when i start it up... It seems like its searching for an idle rpm.
When i put the dist. back in, and adjusted it until the truck started and stayed running (with the tan wire unplugged).
I'm trying to check the timing with a light, but the RPMs jump from 900 to 1300, and everywhere in between. It changes every few seconds. I tried adjusting my AFPR, but an 1/8th turn in either direction stalls the motor out.
Currently:
-Brand new plugs gapped to 35. (put plugs in and started ran motor for 2 days, before i took the intake off)
-Traced the plug wires, they're in the correct firing order.
-my 10n1 chip is in the STK set.
-Engines getting fuel, and spark
-all my grounds and fuses are good.
-no vacuum leaks, that i can find (and i did use copper sealant on the intake)
Any ideas on how to get my truck to idle smoothly?
Currently:
