Syclone #136
Aeroking
e.i.
Re: Syclone #136
just pulled the 5k mile motor.
TurboJunk
questionable
Re: Syclone #136
the taking apart of a truck i now the feeling to well.Its be over 8 months i havnt even looked at my truck but it will be under the knife soon. ALOT of work needs to be done.
good luck
beastmode
Re: Syclone #136
lookin good so far buddy. sorry i couldnt hang around and give you guys a hand for any longer than putting the hoist together.
i think benny put that pipe handle inside the house so im gonna try to get it today... least for when you guys go to put the motor back in
its gonna be interesting next year when you get this baby back together and i finish all my mods and put my procharger on :myclone:
beastmode
Re: Syclone #136
i take it you had enough clearance to just drop the trans and pull it out from under? makin good progress so far man
nice new engine stand :rotf:
Aeroking
e.i.
Re: Syclone #136
its kinda tricky, cause the fuel lines are bolted to the top of the tranny case. but to get your hands up there, you need to drop the tranny down alittle. but you cant, cause the tailshaft on the transfer case hits the crossmember. so i slide the whole assembly forward till it hit the front diff.(leaving me an inch of clearance between the tailshaft and the crossmember) then i lowered everything down enough to unbolt the fuel lines, the i was able to put it on the cart, raise the front of the truck way up, and slide it out the front.
psa cake
beastmode
Re: Syclone #136
ya sounds like a psa cake :roll:
you should throw the hoist in the bed when its all said and done and drive around trying to tow ppls cars... syclone tow truck :rotf:
Aeroking
e.i.
Re: Syclone #136
today, i'll be bending brake lines so i can get rid of the ABS unit.
by next weekend i should have the bottom end of the engine assembled.
i ordered a new A/C evaporator, so i'll cleanup the heater box, and put it back on.
painted most of my heat shields, and started to shine up the firewall/tranny tunnel.
SY2932
Administrator
Re: Syclone #136
That's the spirit! If it don't work, get rid of it
! And you'll shed 18 pounds to boot.
Aeroking
e.i.
Re: Syclone #136
H-beams just arrived, thank you Waller Performance
bearings are on their way from RPM.
then i can start assembling the bottom end.
Aeroking
e.i.
Re: Syclone #136
got a little sidetracked with a new vehicle....
Like it. reminds me of a Ty.
but i'll get back to the truck soon.
SY2932
Administrator
Re: Syclone #136
WHAT?, No Dubs??? J/K SWEET ride :cool:! You should have gotten it in black though since everyone knows that black cars are faster
Aeroking
e.i.
Re: Syclone #136
lol, its a 07 left over, i bought it at Christmas. I didnt want black or silver.
although the blue gets as dirty as a black one would. but blue's kind of a rare color.
Aeroking
e.i.
Re: Syclone #136
started workin on it again.
Mocked up the short block a couple times, for bearing clearance, and noticed that i need to relieve block to clear the rod bolts. Also, the rod bolts need shortened, because they come alittle too close to the cam tunnel.
( the crank spins like butta, like butta )
Since the last update, i changed my mods again.
Instead of a PT63, i bought a GTQ72.
Instead of the 415 cam, i got a 218 custom grind from TurboTime
And i took back the M55 pump, and got a beefier M55HV.
Still waiting on my heads. And deciding whether to leave the Walbro 255 in the truck, or to sump the tank, and run an Aeromotive A1000.
