This is my top end removal which is intially going to a be a Vortec swap but it may lead into a short block rebuilt/refreshing. My wife was away for a little over a day so I acclompished a lot. This project will go really fast with the removal but it will probably be slow to put back together as I clean last fall daily driver dirt/water splash and as I assembly the Vortec Heads/detrmine waht elese is wrong..
Unfortunately I had a funny flash setting, so my picture came out funny, its too late reassembly everything for pictures. Oh-well, I will fix and test all the new pictures.
Here is what I started off with...
Off comes the IC
Then the turbo
Then the DP, Passenger Exhuast Manifold & Throttle Body
Off comes the AC bracket
Upper Intake & Fuel Rails come off
Alternator
Lower Intake comes off
Off comes the Valves Covers, look at the bling
Good bye Crane Roller Rockers
Off comes a LB4 head.
Here is Cylinder 2,4 & 6. #6 is just wet from coolant when removing the heads
Here is my Passenger Head
Off comes the IC
Then the turbo
Alternator
