Re: Top End Removal/Vortec Swap
Having it relocated does two thing, less sensitive (noise mostly is isulated by the intake gaskets) but it also keep it away from the Transmission noise. I don't have flase knock though either.
I didn't length the wire. I instead had bought a kit long time ago that plugged into the wiring off of different GM sensors so you could test them. I modified that, so I didn't have to cut the factory wiring harness.
TurboJunk said:wouldnt that make your false knock situation worse?
QUICK STORM said:dave how did you route the wiring there? i assumed you lengthened the wires.
