4C FED
Absolutum Dominium
Re: Top End Removal/Vortec Swap
For the downpipe hitting the frame, I think there is a little slop in the holes in the exhaust housing.
You can gain a little extra clearance by loosening the 4 nuts that secure the exhaust housing to the manifold. Rotate the turbo so that you are trying to aim the inlet down & the downpipe up. Then tighten it back up.
This should lift the DP off of the frame a little bit.
