Re: Transfer case may be busted
Only way is to compare it to a new chain.
That "sag" you see right now will get pulled out when the cover goes back on because the cover will pull the input shaft toware the "left" as the pic is and it will pull the front pinion shaft toward the "right". The chain manufacturers give you the 50K rule and the viscous manufacturers give the 60K rule. Just a note, it may just be the angle, but it doesn't look like your viscous is seated all the way. You've probably got a thrust washer not set right. Best way is to do it with the input shaft pointed straight up so everything stays lined up. With it laying on it's side like that, the thrust washers on both sides of the planetary just fell straight down and aren't letting the input shaft and viscous set in there right. Go to my
www.primegears.net/gallery on the BW4472 build and look at those detailed closeups of the viscous and how deep it sits into the ring gear when its in there correctly.
Here you go. Here's the pic:
See how deep that sits in there? Like I said, it may just be the angle of your picture.
With it sitting like this:
You'll see it's much easier to line everything up.
One of those billet planetaries and sun gear shafts I'm doing would look really good in there....I'm just kidding. I had to say it though.
