Transfer case may be busted
B
BoostedGMC
Guest
Re: Transfer case may be busted
I just got my case all put together. Everything went right in with no need to force anything. After I have it all done I spin the prop shaft flange to find out it is a little hard to turn. I'm not sure if it needs to be driven for it to loosen itself up or maybe I busted a bearing. When I put the oil seal in where the prop shaft flange goes, I used the flange to press it in. I think I may have bottomed out and hit the center of the bearing in the case causing it to seize up.
B
BoostedGMC
Guest
Disregard that...Turn out it was the rubber spacer on the output shaft rubbing the housing. So I just slid it down and spins freely now.
I bolted the case back in the truck, took it for a ride and my transfer case problems are gone :D
