Typhoon #1215 Mods
ty166
Re: Typhoon #1215 Mods
man alot sure goes on it your garage........ looks great, keep up the good work, that truck sure gets alot of lovin over there.
SEL777
One of 101
Sean, I really like the look of the gauges, and the wheel too. Is it the angle of picture, but the pic looks like the center cap is off a bit?
BowtieLady
Do they still make that steering wheel? And where did u get that horn button? That wheel could almost pass for stock bc it looks like it matches the gray plastics of the interior.
Sean Krupa
Moderator
Here are my LS1 Front and Rear Calipers. It took me about 40 hours to sand down the casting and wet sand. I then polished them on my buffer. I replaced all the seals and boots and new hardware. I wanted something that was different instead of the traditional red. I had the brackets powder coated with a 3 stage Lolly Pop Red for a candy look. For those that say that upkeeping polished aluminum is hard work, I have to disagree because I have my whole engine polished and believe it is alot easier to keep clean than the factory casting which grabs dirt. I also have Drilled/Slotted Rotors w/ Ceramic pads that I'm putting on. I have Renz's front adaptor kit with braided lines and LS1 rear backing plates. All I need is Rear braided lines to adapt to the stock line.
BEFORE (Payed $80 for Front + Rear)
AFTER
SY2932
Administrator
VERY nice :cool:! If you attend a syty meet, you are going home with an award of some sort for sure...
Wow excellent job! I like the way those calipers look. Cant wait to see it all done.
BTW, X2 on the horn button and wheel. Where did the button come form?
Jeremy
Where does one get a JSM down pipe from? I am in the market for one. Thanks!
Sean Krupa
Moderator
Thanks guys, I appreciate it!
those calipers are HOT! did u clear them or left them as is after polishing
I did not have them clear coated, mainly because it might make them look dull. Only the abutment brackets are clear coated after powder coating. I don't think I'll have a problem keeping them clean being that it's no longer a DD.
I got the steering wheel off of Amazon (Grant #1470), it was the cheapest place I could find. You can find the GMC Horn button on Jegs or Summit.
Jeremy, Good luck trying to find a 3" JSM DP. I looked for quite awhile until I found one. Try making a post in the Wanted section.
BowtieLady
I think the calipers are a work of art. 40hr of work on calipers is mind blowing. But the proof is in the pic.
aasltmike
I want to do the LED upgrade on my dash cluster, but IIRC, there was a write-up with pics on taking the cluster out. Did the search and I couldn't find anything...anyone know if I'm right and where I can find it on the board?
aasltmike
Great, that should work for me! :tup: Other question I had was the gauge bulbs...I found the 15 LED bulbs on ebay, but in your pics I'm guessing that the gray sockets are what you can get at Autozone?
Sean Krupa
Moderator
The Gray sockets are the factory ones. I would recommend that you get new sockets from Autozone being that it would be 10x easier. The factory bulb/socket are a 1-piece configuration. You basically have to break the bulb to get it out.
Remember, once you get the LEDs, you have to test each bulb because they are Polarized. It might not work, so you have to turn the bulb around.
Hope this helps,
asmo
Sy #2918
Really nice work, looks like you have a polished a/c compressor or is it a cover? and what a/c pulley is that or a cover on there to?
Props on those calipers they are amazing.
graham1524
Well-known member
Hope this helps,
They don't sell the green or gray holders anywhere. I spent a couple weeks trying to find some.
Sean Krupa
Moderator
They are both covers that my dad got many years ago. The A/C compressor cover is Chrome, and the pulley cover is billet. Maybe if I have time, I can help you find them.
graham1524,
I went to Advance Auto Parts, and they had the gray (black) sockets. They are just 194 based cluster sockets.
