Re: What would you do with $5,000 give or take?
I have thought about doing the Ty daily driver, so this what I would do or look at if I owned one and was going to press it into daily driver duty.
-Scan tool & typical SyTy tune up (should be done for SyTy even if 100% stock, same goes for the scan tool) Get the truck running perfectly on the scan tool.
-Check you radiator hoses, fliud, & see if the clutch fan still works.
-Ditch the Crossver tube. Higher mileage truck are begging for them to break apart and ruin the turbo. I have thought about doing a mini battery and adding second battery.
-Tranny Cooler.
-Quality tranny rebuild- If you tranny is going out and you going to keep the stock turbo, I think you can get a way with a quality rebuild. You in CO, knock on Hartman doors or call up Blake for a rebuild.
-Upgraded propshaft. I couldn't not do a boost launch.
-Motor mounts, see above
-change Front Rear Diff, Transfer case fluids.
-Rebuild front suspension (balljoints and idler arm particulary), ZQ8, upgraded steering shaft would be nice.
-Shocks
-Rear Sway bar. They should have come with one, stock.
-LS1 brakes- the stockers totally suck, they are a liability.
-Flush brake fluid
-Tranny Cooler.
-Shocks
-Flush brake fluid
