(3) 2001 zq8 quick ratio steering box's $140 shipped each
spooldup
Super Member
Re: (3) 2001 zq8 quick ratio steering box's $140 shipped each
Not sure. I never checked mine outside the truck. Was your truck purchased used? Maybe someone installed the box already?
chelo
filthy sy
They do perform diffrent when installed. Not by much though.
ashman
according to the following thread, people are seeing substantial differences in the ZQ8 boxes. this sux as i purchased the box for an increase in steering response.
is there any way to indentify these externally, to see if my original box was a ZQ8?
http://www.syty.net/forums/showpost.php?p=247842
GarnetTy1473
Might want to check with Dave (dgoodhue). I sold him a box a couple years ago and he contacted me about the same thing. I think once he installed it, you could then tell it was the quicker ratio.
spooldup
Super Member
All of the boxes that i have are 100% genuine zq8 pulled by vin number.
ashman
not questioning that it's a zq8, i'm interested in why some are different.
i just finished installation and it's slightly over 2.5 turns lock-to-lock installed, which is the same as the one i removed.
i can't rule out that the one i removed wasn't a zq8. i didn't notice any difference when driving, other than the replacement be much tighter.
could someone with a stock box check the turns lock-to lock (installed and removed if possible) and give us a baseline?
spooldup
Super Member
sounds to me like you might have had a zq8 in there possibly with higher milage.
yeah my stock Ty gear box had alittle over 4 turns L to L, and the ZQ8 i got from this thread earler this year had alittle under 3 turns L to L, andman what a differeance that one turn makes when out on the road, i had always dreamed of steering that tight, i want to pick up one more of these for my Bravada, but have to wait till the funds flow alittle more freely.
But if you want to let go of the one you just bought for cheap, LMK.
spooldup
Super Member
If it comes down to it that you think you have a zq8 send it back for a refund, no biggie.
BLACK92TY
It's never enough
I've bought several parts from spooldup now and no complaints.
I bought the zq8 back in April or May. Very satisfied. Install was real easy. Motor was out at the time. I noticed a difference right away after we got the motor in. Just swap pittman arms and you're good. I need an alignment but that's about it. No an ounce of play in the wheel now.
Thanks spool.
ashman
thanks for the offer! i wish everyone was as easy to deal with as you.
i'll keep it...it's tighter than "virgin gnat booty"...feels like a new truck.
for the record...i'm not blaming anyone other than myself. i should have done my research. spooldup's zq8 boxes are TOP NOTCH :tup: and he is and excellent person to deal with.
ShuggsRR
Sooo... No boxes available right now? I think I'm ready for one in my Tyclone.
slow91
What are the advantages of this box?? I've just bought my Sy and would like a little more responsiveness from the steering......does this help??? TIA.
spooldup
Super Member
There are a bunch of positive reasons to install one of these. First is that 1-2 inches of play when you first turn your wheel left or right is gone. Second the ratio is tighter so it's less turns lock to lock and third it helps with the wandering the syty's suffer from especially when you upgrade the steering shaft as well.
spooldup
Super Member
Hey guys the new shipment has arrived. I only received 3 this time and two of them are sold. I have 1 left that is packaged ready for shipment if anyone wants it.
Syclone#2960
What ever it takes!!
LMK if you still have one for me.
Thanks!
toolmann
hey ashman..i want one of these now soo iv been researching it a bit,and iv found a possible reason why there may be a difference in the boxes...maybe.
from what iv read,the stock s10 blazer/pu boxes are a straight 17:1 ratio.
the extended cab s10 boxes are are either 15 or 13:1 variable ratio box
sooo...with that in mind...zq8 standard cab extremes,and zq8 extended cab extremes,could have different ratios boxes??
still looking into it...
