Hydroboost unit with master cylinder and proportioning valve $75
fivetodrive
CRISPY
Re: Hydroboost unit with master cylinder and proportioning valve $75
Yes. I had a coupon at the junkyard and have 3 ready to go!
Excellent vid - so you need the lines from the 94, the stock Ty lines won't work? If so then I guess i am going braided.
When are you making an engine install vid and a 4L80E install and wiring harness connection vid? :D
How is Crispy these days? :D
fivetodrive
CRISPY
When the 4l80e comes back from the rebuild I will make a video.
The engine removal video will probably never work very well for you guys. I removed the entire front clip! It makes for easy access to the bolts though!!!
Crispy is in an idefinate holding patern right now. I am still collecting parts and building a second 4l80e (ready for someone to just drop in, with the 27spline output shaft, a TCI controller, crossmember, and adapter plate) to sell, hopefully it will help me upgrade to the PCS controller... It only costs a few hundred more to build two trannies instead of one, when you have all of the tools and everything out. You just need two tables!!!
65MALI
Oops double post, disregard
fivetodrive
CRISPY
PM replied to. Thanks! Still have a few of these!!!
65MALI
Damn you sure is slow, projects at a standstill, waitin on them hydroboost units let me know whats up. thnx
fivetodrive
CRISPY
I screwed up my back and getting a personal check to the bank is not on the top of my list... The hydro units are going out tomorrow. Thanks for your patience... Paypal or a USPS money order makes life a lot easier...
fivetodrive
CRISPY
Thanks... Once you screw up your back it never seems right and it is easy to hurt it all over again...
Glad you got them ok! Thanks again...
Aaron
fivetodrive
CRISPY
TTT I have a few of these astro units boxed up and ready to go...
I also have 2 truck hydroboosters with the longer push rod that bolts up easier...
Aaron
