Typhoon #1215 Mods
Sean Krupa
Moderator
Re: Typhoon #1215 Mods
My Dad helped out today and removed the A/C bracket and pulled the distributor and lower intake while I was at work. Next is renting a Power steering pulley puller to get that off, then Heads.
Sean Krupa
Moderator
Got the Drivers Head off today. No going back now :lol:
The Beauty of Meth injection. Look at those 100k mile Pistons!!
Sean Krupa
Moderator
Yep I was surprised as well. I will take a look at the valves soon to see how they look from Meth.
It's just a six
Super Member
I had asked Julio to post some pics of his piston tops from his Mustang on the Buick forum. He posted the pics & his pistons were clean as well.
Meth cleans them well as does water injection.
Sean Krupa
Moderator
Recieved my Sheet metal Valve Covers today from Aaron (fivetodrive). As you may know, I will be Polishing them soon :D
Sean Krupa
Moderator
They are for aftermarket rockers.
Pulled the Pass side Head last night. Almost should've pulled the motor, but my Spare Ty motor is on my engine stand and I'm not in a rush anyways. At this point I can take my time pulling the Cam and such. I will be collecting parts soon and hopefully get some needed parts for Xmas :lol:
In the mean time, I can send out my Lower intake to Fivetodrive for a modded Vortec one and Powdercoat stuff.
SEL777
One of 101
It looks like it may have been easier to pull the engine....jeesh, did they design it to be a PITA to work on everything on these trucks. I know how it'll look when you're done tho! Good work, keeps me motivated too.
Sean Krupa
Moderator
Decided to take the Exhaust housing off to Port the wastegate hole. Pretty big mismatch going to the RPM Downpipe. Not done Porting yet, here's the Before pic.
It's just a six
Super Member
Don't port too much in the wrong area, or else the valve could possibly get stuck.:2cents:
Also, by opening up your wastegate hole, your base boost pressure will drop some depending on how much you open up the hole.
It's just a six
Super Member
Sean Krupa
Moderator
Thanks for the links! As stated in the first link, Mike Lee said you can port the hole quite a bit, close to 1.5". I shoulda specified what Wastegate I'm running. :tup:
Gnocide
turbo game burt reynolds
the nice thing about the housing is ,
its already marked, centered and measured where and how much to cut
dont go beyond unless your puck is bigger
Sean Krupa
Moderator
I did some porting the day I posted the pic, but didn't take any progress pics. I will take some tomorrow when I work on it some more.
Sean Krupa
Moderator
Here's the After pics of the Porting. As you can see, their is still some mismatch but didn't wana go to crazy. Also it was hard to make that flat spot round, which does't look like it'll affect much.
RealFastV6
@jb_and_his_coffee
Hard to tell so I'll belabor the point anyways - but you want to make sure you have a nice smooth radius on the inside of that hole. The radius is as critical as the size of the hole.
