wantingasy said:I would get this. http://www.raceprovenmotors.com/cart/product_info.php?products_id=485 Then you'll have the vacuum fitting for the gauge, a new brake booster check valve ( which has been a big problem for rough idle), and also for good looks :tup: The price isn't bad either :2cents:
BacDoc said:So frustrating.
Richie Rich said:You may have to manually change your com port once you select to record. Well atleast that is how mine is. Com1 is more than likely what it needs to be set to.
Richie Rich said:Are you sure the driver is installed correctly for the USB adapter? Did you check you "Device Manager" for any unknown hardware? Did you load the driver before you pluged in the USB adapter? Just ideas.
BacDoc said:Anywho I had the truck out tonite and noticed when I use about 50% of the pedal it runs good but if I apply more or WOT it seems to not stall but the engine gets louder and the RPM's don't move. Almost like a clutch slipping but not. My best guess is a bad fuel pump not getting enough fuel to the cylinders. If only I had the Datamaster program working!!!!
cloned 1 said:that kinda sounds like your cat is plugged up (if you have one)
cloned 1 said:i would put the afpr on and the walbro , you got a chip for tha 3 bar right? i would get it running right first before doing chips, 3 bars and the like, and ill bet 100% of the board would agree. but i would unhook your cat and drive it to see if thats what the prob is. just make sure to run your vac line from your turbo to the wg so you dont overboost. good luck
